OR You could use one of those Shamwow!!
  • Extremely absorbent
  • Cleans up everything
  • Machine washable and bleachable
  • Will not scratch her
  • Last for more than 10 blows!
"You'll say WOW Everytime" LOL
in the middle of a heated, steamy session you jumped up and yelled "WOW! AND THE MESS IS GONE, THANKS SHAMWOW" didnt you..
and thats why he's your ex now
ROFL :banana:
Oh my shes on fire this morning
Hahahaha! Not quite lol
hahaha the thread is win this morning.
Good morning all :P
You made a key assumption back there, Tristan - that he even made it to the end of round one in the first place. :banana:
then he must have missed your mouth at the end of round 1 ;)
:P
Yeah he broke rule 101 - Never miss and get it in my eye :banana: lol
Anyways.. Enough about my ex.. lol
He's still one of my best mates.. :D
Edited by 83CKS
Good morning all :P
It's pretty easy to complete round one.. Quick as, for Some or should i say most...
It's like playing with a loaded gun sometimes.. lol
Im going to get on a plane back the beautiful Gold Coast :P:D;)
Cya ppls :banana:
Aww man. envy.
I wish I could be chilling out down the coast today!
glad you said 'most', and not 'all'... because i'd make your arms fall off from exhaustion and you'd still be cursing me for not being done :cool:
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
