sorry fellow sau readers, i dont have a performance business so i don't no anything. many apologies.
ps: defi style = is pretty much the blacked out screen look.
No mate, your just being the typical tight ass about it..
i deal with products on a day to day basis..
its just the same when i wanted to talk about electrical parts with u.. you deal with lights and wall fittings on a day to day basis as well.
Dont forget mate,, your talking about the Defi BF series that runs a control unit.
Hey tas, i need a gauge cup for my 45mm Omori gauge, you able to get that stuff still? I also need the wiring loom for an Omori Exhaust Temp gauge too. The last omori site i was looking at doesnt exist anymore.
tis true i am a brand whore!!
u should see the parts line up for the R32
the omori guages.. ill hunt around for you mate..
they stopped making them yonks ago i believe..
but give me a few days see what i can dig up.
u mean like a cup holder to mount on your dash or something like a pillar mount?
i been using that new Wurth skin protection cream..
rub it on before work then it helps to wash all the shit off your hands quicker..
but even time i wash my hands and dry them then get slightly wet again.. feels like i put my hands in oil..
lol
nah a gauge cup as in the type you can screw onto you steering column. I dont want to dril a hole into the dash to mount it. Cheers for that tas, yer the omori website doesnt exist anymore, i only got 2 gauges
Wurth products are good, we use them at work too, hand cleaner is good also
so i got handed a 6pack by my neighbour earlier..told me its his new morning beer
man it takes different and good hey...those new carlton fusion with natural lime
man..its like a beer to have in the morning to start the weekend of massive drinking!
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
