sorry fellow sau readers, i dont have a performance business so i don't no anything. many apologies.
ps: defi style = is pretty much the blacked out screen look.
No mate, your just being the typical tight ass about it..
i deal with products on a day to day basis..
its just the same when i wanted to talk about electrical parts with u.. you deal with lights and wall fittings on a day to day basis as well.
Dont forget mate,, your talking about the Defi BF series that runs a control unit.
Hey tas, i need a gauge cup for my 45mm Omori gauge, you able to get that stuff still? I also need the wiring loom for an Omori Exhaust Temp gauge too. The last omori site i was looking at doesnt exist anymore.
tis true i am a brand whore!!
u should see the parts line up for the R32
the omori guages.. ill hunt around for you mate..
they stopped making them yonks ago i believe..
but give me a few days see what i can dig up.
u mean like a cup holder to mount on your dash or something like a pillar mount?
i been using that new Wurth skin protection cream..
rub it on before work then it helps to wash all the shit off your hands quicker..
but even time i wash my hands and dry them then get slightly wet again.. feels like i put my hands in oil..
lol
nah a gauge cup as in the type you can screw onto you steering column. I dont want to dril a hole into the dash to mount it. Cheers for that tas, yer the omori website doesnt exist anymore, i only got 2 gauges
Wurth products are good, we use them at work too, hand cleaner is good also
so i got handed a 6pack by my neighbour earlier..told me its his new morning beer
man it takes different and good hey...those new carlton fusion with natural lime
man..its like a beer to have in the morning to start the weekend of massive drinking!
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
