Yeah, I'll msg you when I leave work if you like
I fell asleep - but yes!
Quite a possibilty. Interested parties say I?
I
however i must fail you for the sub, im sorry
What sub? I can't see past the FIVE STUD RIMS!
that's right... I went there :blush:
isola u coming over?
I do believe I am
isola, got your exhaust here buddy
finally got fish and plant for the tank!
1. thought it was already there?
2. Wicked :ninja:
Just a tip...
Fish eat more then once a year
:D
Those bastards are ALWAYS hungry! Don't ever dangle your boys in the tank ;)
tasman, i'm coming to visit you soon, leaving work at 3 (y)
Hmmmm... tis 3 now. I might start my walk...
was thinking drinks at the shop
ooh wait your working :blush:
Oh ha ha and
ha
Thats it next time you want me to come around for drinks. I won't! No wait a minute that's not right..
Next time I will! Ha take that ! Bam
    • Did you take the MX5 for a Blat around the Track at all?
    • LOL, "they said it might be slippery"..... 30 seconds in your off, 60 seconds in white twin backs into the corner That new track looks good, and the Datsun was chopping cars quite nicely
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
