Martin by any chance were those two smoking hot cops in the area of Albion/clayfield? cause if so its true, they are actual cops. I have seen them before. Many an early morning RBT setup in that area, its one of our test drive runs (rougher roads in the backstreets there, good for testing for suspension noises)
Spot on: Clayfield. I think its Melton Rd, near the corner of Junction rd
the big operation? or a job?
Yer there is a couple hotties working around that area, pretty sure they are from hendra. Also some hot ones working for fortitude valley station
When I got pulled over by an RX8 in Ascot a few months back, the chick that spoke to me had tigs that put Terri to shame!
Edited by Isola
Watched this on SBS. Very weird zombie movie with aliens in it. Weird but kinda cool. The sheila in it has four pump action shotguns mounted together.
worth watching?
what country?
I <3 Zombies
It was a good watch actually. Especially the way they brought in the aliens. I think it was a oz movie.
I'd give it 3 "brrrraaaiiiinnnnssss" out of 5
Its almost as good as that NZ zombie filum
That i'd give 4 squidgy innards out of five.
But nothing is as good as Shaun of the dead..
Farkn lol love that movie.
    • I did basically the same procedure on a ZF6HP but the reason to pull the valve body is to replace the seals between the valve body and the transmission which are notorious for leaking pressure with age causing poor shifting and burning out the clutches. If you just wanted to exchange all the fluid you should be able to undo one of the transmission cooler return lines to drain into a bucket while using the pressure filler to keep it topped off.
    • The title should have posted "EFR7670 exhaust housing selection RB26" I can seem to edit thr title on my Android.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
