quick! drip a rag into thinners and place in bag
then proceed to place bag over nose and mouth and take deep breaths!
then walk the streets asking for smoke or a dolla
$1 says you have to wait 7 weeks for that clutch to be done
7 weeks later,
"wow tristan how come your car has been stripped of all stickers and there is nothing in your signature anymore?"
"oh no reason..."
hmmm... covered in thinners + lighting smoke...
i wouldnt say that..
it would be more like
"Tas wow i didnt know u had a worked 180 for sale oh did u know my car got stolen?"
no need to worry about it because it'll be done and sweet by next weekend :/
pffft... only if you ask me nice enough to help him with it :/
in that case im not asking nice at all :)
a week for a clutch and service is ample time :)
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
