Im prob just reading this wrong but this is what I found.
The GTS-t Type M included larger five-stud 16 inch wheels, four piston front callipers and twin piston rears. ABS was optional (except for the GT-R), viscous LSD was standard on all turbo models and optional on all but the GXi. Nissan also produced 100 Australian models of the R32. These were the only non-Japan only Skylines ever produced. There was also a 4WD version of the GTS-t Type M, called the GTS-4.
Please explain :)
Just so you all know.. HAVE YOU EVER SEEN A GENUINE TURBO! R32 that wasn't a Type-M.. No, you havent. They all have 4 pot fronts and 5 stud hubs. It's just a marketing hype.. All friggen turbo R32's are Type-M's with different trim levels, just like options and trim levels on any other car.
Please explain :)
Learn about full stops. :D
The 100 Australian models were GT-Rs. They weren't produced in Australia though (AFAIK), they were produced in Japan but locally delivered by Australian nissan dealers (To be fair this information is not described in that quote). The bit aboute the GTS-4 is the next sentance and is unrelated to the previous.
It is definitely poorly worded. Just goes to show you can't always trust wikipedia
Ah k cool bananas :D
Yeah I obviously dont know much about cars thats why I was asking if that stuff was right :down:
ROLL CALL!
my brothers formal is on tuesday night - and as he was discussing a few weeks ago he was hoping if we could all do a drive thru for him
he wants to get there at 6 and its being held at the hilton in the city
hopefully some of you guys can help him out :)
ROLL CALL!
WWWWWWWWWWAAAAAAAAAAAAAZZZZZZZZZZZZZZZUUUUUUUUUUUUUPPPPPPPPPPPPPPPPPP!!!!!!!!!!!!!!!!!!!!!!!!!!!
so thats a yes?
    • Thanks. We getting some parts along too so he will be solving the speed issue like next week so i will let you know what he came up with.
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
