Im prob just reading this wrong but this is what I found.
The GTS-t Type M included larger five-stud 16 inch wheels, four piston front callipers and twin piston rears. ABS was optional (except for the GT-R), viscous LSD was standard on all turbo models and optional on all but the GXi. Nissan also produced 100 Australian models of the R32. These were the only non-Japan only Skylines ever produced. There was also a 4WD version of the GTS-t Type M, called the GTS-4.
Please explain :)
Just so you all know.. HAVE YOU EVER SEEN A GENUINE TURBO! R32 that wasn't a Type-M.. No, you havent. They all have 4 pot fronts and 5 stud hubs. It's just a marketing hype.. All friggen turbo R32's are Type-M's with different trim levels, just like options and trim levels on any other car.
Please explain :)
Learn about full stops. :D
The 100 Australian models were GT-Rs. They weren't produced in Australia though (AFAIK), they were produced in Japan but locally delivered by Australian nissan dealers (To be fair this information is not described in that quote). The bit aboute the GTS-4 is the next sentance and is unrelated to the previous.
It is definitely poorly worded. Just goes to show you can't always trust wikipedia
Ah k cool bananas :D
Yeah I obviously dont know much about cars thats why I was asking if that stuff was right :down:
ROLL CALL!
my brothers formal is on tuesday night - and as he was discussing a few weeks ago he was hoping if we could all do a drive thru for him
he wants to get there at 6 and its being held at the hilton in the city
hopefully some of you guys can help him out :)
ROLL CALL!
WWWWWWWWWWAAAAAAAAAAAAAZZZZZZZZZZZZZZZUUUUUUUUUUUUUPPPPPPPPPPPPPPPPPP!!!!!!!!!!!!!!!!!!!!!!!!!!!
so thats a yes?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
