ROLL CALL!
my brothers formal is on tuesday night - and as he was discussing a few weeks ago he was hoping if we could all do a drive thru for him
he wants to get there at 6 and its being held at the hilton in the city
hopefully some of you guys can help him out :D
This tuesday? damn, wish you'd asked a couple of days ago :)
I'll try to get out of cricket, but it will depend how many people want to play
GTS4 ? ? ? Is that the AUS made RB20det wit 4wd ? ? ?
JDM
The GTS4 is essentially a poor man's GTR. When Nissan released the GTR, the Japanese folk who lived in the mountainy areas with the rough roads and snow and crap really wanted them, but couldn't afford them. Nissan built an RB20 powered, heavier version of the GTR. The GTR uses all the fancy aluminium parts for some panels, and running gear etc. The GTS4 uses steel. So basically: it's the standard GTST body (so not wide body like the GTR), with the ATESSA 4WD from the GTRs, single turbo RB20.
GTS4s are less common because it is hard to find ones that aren't rusted out due to all the snow and salt.
Whats planned for it? I have such a soft spot for gts4's. More so when rb20's are kept.
The little motor that could!
For now, probably just a brake and turbo upgrade. HICAS lock out, drift switch. Cosmetic changes.
Down the track I'm going to look at a different engine (maybe a 26)
ROLL CALL!
hopefully some of you guys can help him out :)
If I have my car by then, I will. If I don't... well let's just say I aint walking.
ROLL CALL!
so like just a drive by ?
    • Only if you do not You will not be able to drive it with any serious load without risk of it pinging, which will either slowly or rapidly kill it, depending on how bad it is.
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
    • lol already been put in temporarily 3 years ago
