:wub: Its even better when your hungover
Ah well thats what you get when you take advantage of the free beers at the crissy party :wub:
Yep hangover's + work = great day. Stupid bourbon. :(
well it used to be an actual shop in Brisbane... and as far as I know still exists. Thought we were talking about that one
thats all jap
+1
JJ or JustJap are located...
101 Bath Road, Kirrawee
Sydney - NSW
Australia 2232
placing a group order soon if you want that vent?
and marto just finished installing win 7. seems more friendly so far. pm me if you wana check it out :(
Oh did you get on it too?
Yep dad came over with my b'day pressie. Got stuck in. I wonder if I can get worker's comp for this ? I am the victim here.
Oh happy birthday man :D
And yes I think you should get compo :sick:
Birthday's not until tomorrow, but thanks anyways.
Should have brought the bourbon in with me. Hair of the dog as it where.
Righto I take that back then and ill re deliver it 2moz :sick: hehe
Ah well im off into the pit to do some work in the 35° heat :D
Damn them salt mines, damn them I say! All the way to heck.
u still down in toowoomba?
Come on keep up with the times.. I'm at work lad. The only place to be.
Apparently its all the rage in El Salvador.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
