Me too . . . I cant sleep past 6am :P Unless im extremely hung over :)
I am normally up at 6/6:15am. It takes about two weeks off for me to be able to sleep in past 7:30 or so :D. Even if I'm up till 4am drinking
I am normally up at 6/6:15am. It takes about two weeks off for me to be able to sleep in past 7:30 or so :) . Even if I'm up till 4am drinking
Haha yeah man that sounds like me . . . Whats wrong with us ?
18 is f**king freezing! Whats wrong with you? :P
+1 :D
Hahaha ... The Air-con in my house is on 24/7 ... During the day I have it on 20deg & at night I put it on 18deg, I have a blankieeee so it feels like at least 24deg :D LOL
yo i can sleep any time of the day until any time of the day regardless of temps i <3 my bed
and martins - its pretty comfy too
Thanks :D Also getting a Turbo & Ecu upgrade in the next month or so ... hehe!
4th, is that a drift prac night? If so, then most likely :)
f**k yeh :P
Wiiin! See, people like us are normal :D
As for Martins bed, that's a bit gay but hot at the same time LOL :P
alarm goes off at 5am every morning. then on sundays i normally wake up violently around 5:30 thinking im gunna be late for work :P then I realise its sunday and i can sleep in lol.
I have no energy for work atm f**king hate this place.
alarm goes off at 5am every morning. then on sundays i normally wake up violently around 5:30 thinking im gunna be late for work :D then I realise its sunday and i can sleep in lol.
I wish I could automatically wake up at 5:30am LOL Doesn't happen in my house :P I don't even get up for work until 8:30am!
sooo when are you replying to my msg u dog
what about that time i took all the blanket and you got up at 4am?
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
