Can't believe you made me hunt for this........
Martin:
If I buy the beers, would you like to help me install my head unit and kill switch?
As long as its good beer, or bundy and coke :D . Wasn't your kill switch(s) going to be an epic project?
Oh, and the drift switch :)
MUNGIIIIEEEEEE!!!!!!!!
get a bag to put it in.
I've heard that get called "man-wrapped" before :D
I tried to get something for my mates engagement gift-wrapped the other day... DJ's and Myers don't do it mid(ish)-year anymore. Had to go home and wrap it myself... god it looked awful. :S
Real men don't wrap stuff...sheesh
we just nail it to things.
post corrected.
also - gift bags FTW.
also +1 - I run my air con on 16 with the fan on as well. Everyone else is a pussy.
post corrected.
Excuse me, you forgot one important thing.. To which I am slightly dirty on
:D
:D
I just sent you an SMS. I only just got home 20 mins ago man. I haven't had time to scratch myself today. I was flat out from 8am until now. I'm really sorry :)
I'll have to do it tomorrow, I'm just about to send the email so it's there for you.
Sorry :)
Sorry :)
Bout bloody time. Sheesh I don't know. What kind of show you running here :D
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
