Woah... all the way down the coast. You're getting serious.
Go on the for sale section. I always see a couple Z32 on sale when I browse the latest thread section. Hope everything turn out well.
Hows the convoy going?
yeh pretty serious , over f**king around and these guys know their shit
convoy is looking good - you joining in bro??
i am hunting a quality z32 if anyone knows of one going for sale
hunting the whole car? or a part?
because there was a Z32 I NEARLY bought before the FO'. It's still for sale over in Carseldine if you're interested.
no john, the afm lol
NEWS
the 180's SR is dead
owned it for under 2000km and havnt even had a chance to driver her hard and shes f**ked
spent all morning down the coast organising a solution and plan for her :D
which is getting put into place as we speak, i'm in good hands
also saw eugene's 180 trailor, and yes i did touch myself
HO'LAY bro that sucks, sorry to hear :(
Good luck with wat eva you decide to do :)
PS. Hurry up an book that trip down near my joint so we can go get loose :bunny::)
SEVERE THUNDERSTORM WARNING - SOUTHEAST QUEENSLAND
for DAMAGING WIND and LARGE HAILSTONES
For people in the BRISBANE CITY and parts of the LOGAN CITY, GYMPIE, MORETON BAY, IPSWICH CITY, SUNSHINE COAST, SOMERSET, SOUTH BURNETT and REDLAND Council Areas.
Issued at 5:59 pm Tuesday, 17 November 2009.
The Bureau of Meteorology warns that, at 6:05 pm, severe thunderstorms were detected on weather radar near Conondale, Jimna, Upper Brookfield and Wacol.
These thunderstorms are moving towards the northeast.
They are forecast to affect Nambour, Mapleton and Borumba Dam by 6:35 pm and Brisbane CBD, Strathpine and Kandanga by 7:05 pm.
Damaging winds and large hailstones are likely.
yuck hail stones!
Oh ok... well I wasn't sure... just said Z32. Can't help you on an afm sorry.
hows the 32 coming anyway man? how far away is she?
good to see you got your prioritys right :bunny:
Skyline > Mercedes
Hehe yup, it might be a 100gs Merc but it can stay outside, the imports are taking up the twin garage :) LOL
Rain rain, go away dammit >.<
Nah rain can stay, hail can garn.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
