loloskates
Today's Top 20 Posters Member Joined Total Member Posts Posts Today % of today's posts
astrotristan2 2nd August, 2009 1,759 55 3.13%
Elite Racing 3rd May, 2004 4,239 33 1.88%
Brandon 2nd October, 2007 1,034 23 1.31%
i dont see anything wrong with this, in fact i think it would be bad of colin not to at least ask his sister if she would like to go with martin.
I'm goin to be far out west, good fun out there
loloskates
You trying to catch up? Josh had like 100,000 post or something. Then some guy reset it....he was pissed!
Oh and...
In before every muthaf**kaaaaaaaaaaaceptsmittyyyyyyyyyy!
Mmmmm early Saturdays.
Martin - gotta make a quick run to the shops on the way to your place because I didn't get enough black wire. No bastard had any heatshrink either :D
Should be there in... approx 1hr.
I'll let you know when I'm close (that's what she said)
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
