brandon,
just checked this pic, it was uploaded on cruisingbrisbane from thursday @ harry diner, buahahah car is dirty, nice cameras show the dirt even more loool
hey mang, sorry didnt reply your pm, f*kin sau limit shit, but yeah its all boring shit atm. wat spec on ya rims? size / offset etc?
reading the mail never felt so good :)
you got work tmr at 1 again man? or usual at 630?
back to the usual but might have another late start this week. i like night shift :D
hey mate,
its all good, do tell me if u need a hand, fackin bored all day , rims i think are Advans Ra3-DT 18x10 +19 wrapped in nankang 255's all around, apparently very very rare rims, were on the car when i got em, hated them but kinda grew on me, planing on work emotion xd9 18 x 10 + 18 soon in white,
what are you doin to the 32?
Edited by brizzy_rocker
well let me know you sly dog and we'll do some work on the 32 :)
hey mate,
its all good, do tell me if u need a hand, fackin bored all day , im not sure about rims, but i thnk theyr 18x10 +19 wrapped in nankang 255's all around, apparently very very rare rims, were on the car when i got em, hated them but kinda grew on me, planing on work emotion xd9 18 x 10 + 18 soon in white,
volk gtc's!! do it do it
and the question is, what isnt dave doing to the 32... :D
not much, just a few little things...
when u get ur new rims you gotta aim to fill the guards up, and then put a little roll on them. then make em look the shit. like so...
haven't finished yet, but looks the jizz.
Edited by 32_Dave
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
