Middlemount if you know where that is. About 2hrs from Emerald up north towards Mackay.
Those 57d are the perfect drifter rims imo. Cheap and good + you get all the attention you need with the colours they offer. Hahaha.
Yes. Not all Gramlight but the specific design I'm suggesting. The 57d were quoted by Streeter
Comparing to
These would be a lot cheaper with the current exchange rate sitting around 85?
Brandon:
Wheels of choice for your car would be Gold Gramlight 57Pro, Gold GTC or White LMGT's
Don't forget that you will pay around 20% more when you go to pick it up from the docks in custom duties and GST.
Also, even if the rate on xe.com says 85yen, the rate the bank will be paying is only going to be 82yen and you have to minus 2 yen on his side also. So if xe.com says 85yen then expect to be paying at approx 80yen and $1800 will actually cost you an extra $360 to pick up when it lands
I wanna know the design part of things rather than operational for starters. And I'll need the commission experience if I wanna go down the path I'm planning.
What have they got up there that they are working on? Power plant or something?
Nah too expensive for drifter rims. Better off buying second hand since you're just gunna wreck them anyway. imo anyway.
You should ask streeter if he can send each wheel via EMS one at a time. You will pay a tiny bit more but avoid custom duties
Now you're on the trolley ;)
In other news. Who is going to the SAU Qld Christmas dinner? I reckon I'll put off paying my fine till the 14th and make an appearance :)
Yea I know that. That quote I got was long ago before I bought these LMGT4. I wouldnt have having those hideous coloured rims on my car thats for sure. But if I'm having a drift car say 180? I'll get them.
No... I'm working for a Coal Consultant.
www.sedgman.com.au
We design, construct and operate coal mines.
Currently I'm working on this job thats been put on hold for 2yrs... and its a shit 1
Yeah but once you hit the 1year mark you get to be the giver ;)
You're a worry dan lol.
Cryptic hints lol. I don't think Tristan is paying attention.
www.sedgman.com.au
True sounds pretty good.
do they need environmental consultants?
Oh wait i shouldnt leave here this time next year i will be preparing for my long service leave!
There are engineers on site that sit in offices all day designing/planning new u/g and open pit shiz.
Will I assume your talking about wanting to be involved with the civil design stages of the sites ? eg. processing plants and other structural aspects ?
Did you study environmental science ?
Environmental Consultants ;)
What do you do in the mines Dan?
I'm an electrical/controls engineer bro. I'll really just be doing the maintenance stuff if I'm onsite. Its normally the process boys that decide what to upgrade etc and from there the other discipline will get the work done.
Thats a bloody good question! Yes Dan, what do you do in the mines???? Must be a desk job since you have a whole lot of whoring time!
I already told you , Im a giver . . . . Oh wait do mean my job ? lol
Im a surveyor ;)
Is it standard surveyor stuff while the mines are under construction or is the place your working at operational?
Maintenance = suicide. I wouldn't be able to do that anywhere especially if I was going to be stuck in the middle of bumf**k nowhere.
Geeezzzz that post was a bit slow since the question is answered ....
Yep fail.
Dan Yep i did environmental science
Colin, dont be upset that we get paid lots to do pretty much nothing except write reports that ever so slightly change the project...yet every one has to wait for them because of silly environmental legislation haha
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
