Try having a monthly report + a progress claim. That'll do wonders to your day. Oh did I mention constant phone call from the boys on site with RFIs.
RF what now ? :rofl:
RFI = Request For Information.
Spend most of my day responding/sending those f**kers.
Progress claims suck balls but I don't have to do them which is sweet. I have to do Audits though which is pretty much just getting abused by subbies for 30mins at a time while you tell them they're doing it wrong.
What the...? I'll take the frogs for porridge and bananas for frying. You can keep the fur to yourself. Oh and save me another post if anyone's gonna go "WTF?!"
http://occasionalepicure.blogspot.com/2005...g-porridge.html
http://en.wikipedia.org/wiki/Pisang_goreng
There's no fur on frogs and banana's have no bones.
See thats the type of info I can give you
not quite sure how your post is related tristan... if you look again, you may notice that the photo I posted, contains one of the baskins girls. It was also directed at Martin... so yeah, unsure why you took it in that direction
i was refering to that joke you told me;
what is better than twentysix year olds?
there are 20 of them..
f**k ray white are useless kents.. "you didnt put a mobile# on the application so we couldnt call you... oh wait, no you did put your mob# down, sorry mate, ill get back to you tomorrow"... after spending 1o minutes on hold..
I didn't tell it to you! you asked me. I just knew the answer because the jokes is older than both of us combined
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
