yo sup?
Not much hey.. Still trying to convince this dude to sell me his wheels.. :D
He posted them for sale.. Now decides he likes them too much...
John, your a history buff right? Can you find me the quote from one of those Nazis (think it was hitler, but may have been goering or someone else) thats something along the lines of:
people will accept any imposition/limitation on their rights as long as it is in the guise of protecting the children
kthxbai
If you're still on:
"The state must declare the child to be the most precious treasure of the people. As long as the government is perceived as working for the benefit of the children, the people will happily endure almost any curtailment of liberty and almost any deprivation" – Mein Kampf page 403
Edited by Isola
So I'm probably a no show this Thursday. The car is hiccuping and hesitating like I have a leak somewhere. My other thought it that it might be my injectors, not sure yet. All fluids are fine, temperature is fine, but whenever I accelerate she hesitates and then goes from no boost to full boost, or struggles to hold boost (especially uphill).
I don't want to risk blowing something up, so for now I'm semi offroad until I get some fundage together to get the car looked at. That probably won't be until the new year thanks to the Christmas season sucking away all my money :D
So this also means I'm out for this weekend down the coast. And probably out from Wednesday/Thursday meets until I can sort out the problem.
sounds similar to what josh's problem was talk to him.
i sell you some wheels :(
It's fun fun fun... walking to work next week and you can probably count me out for thursday's too.. Not unless I can get a lift that way I can be drunk :(:D
Other john is the new guy, nobody cares :D .
:blink: awww awww awww awwww
you often seem to miss about the first 3/4 of the day :P
must be an unemployed bum thing, sleeping in till 2pm
I work part time and study full yet somehow I manage to wake up around 1-2pm during the week. Use to work 20hrs a day so i'ma sleep in as much as possible. Isola, keep living the dream!!!
I've had mine... pommie said he was gonna get them. Really good stuff for 11bucks. Beats KFC anytime.
Absolute filth comes out of your mouth Brandon.... :(
I don't eat seafood :)
Prefer the sausage huh? :D
Pm'd ya.
Anyone else for a good pm'ing... sounds raunchy
Side note : john idle's at 2000rpm
I'm starting to wonder if it might be your head gasket after that overheating situation you had... any smoke out the back when you rev it?
and to think u just got it serviced..
have receipts?
Yep sure do
I didn't get a pm. Wanna help fill my inbox?
Can do
don't know lets find out give me five
Yep sure do
Can do
Nope no smoke... receptionist gave me a weird look though as my car is parked right next to her window :D
how hot did it get jase?
doubt head gasket more like cooling system - lack of pressure, weeping radiator or split in hose. or as u said earlier pump and or thermo not opening but dans idea with the raditor cap sounded reasonable did u find one?
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
