bahahahaha
that explains the 4 lanes....
go on john - make reference to it - with a pic from the first fast and furious hahahahha
nah, it wasn't his thread. He was just sticking up for the other guy that you told to f*ck off to another forum. Would have been good if he started the thread though.
ooh i see
i remmeber how he went on his own tangent for ages hahahaha
ok, so... I might have thrown another log on the fire :)
and that is????
he used to drive a 4 door 34 auto - but he sold it - so thats a lack of log :)
Erm... xmas party and start of holiday? lol.
fair call bro :D
P.S. Tris: Wednesday = next test starts to help keep me occupied for my final 3 days at work :)
ah the old cricket
brilliant
I see lots of lurkers
:thumbsup:
yoo hooo!
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
