Josh I have a 70k deposit, find me a townhouse with 3 bedrooms and at least one garage plus visitor parks that i can steal
for 70k down, I can get you into a friggin New Farm place, that would be the envy of most.
But serioulsy.. If your not dealing with other agents, I can just act as a buyers agent on their stock, in the area's you like.
Costs you nothing, my duty of care is with you and not the seller, therefore you know what I know about the properties in question.
Joshwe are pretty much looking for the general area we are in, should be plenty in Fairfield, Yeronga, Yerongpilly, Annerley and Moorooka perfer to keep repayments around 550 to 600 a week and close to some form of train station or decent bus route would be ideal (no parking at my work :ninja: )
i have 34.25 working hours left
might have to plan some field trips and spend half of that driving around
Working hours left for me would be about 8 or 9. But will actually be about 1 or 2 probably :ninja:
    • If your tuner can't make the car idle like factory, I'd get a new tuner. These injectors are fantastic and I'd have very serious concerns about a tuners skill set if they couldn't get them to idle well.
    • It's highly likely you will find something. Alternatively, a quick design and order online from chaina and you'll have a perfect solution
    • Idle Lambda target is off by .4 but I reckon the VE table is not correct. If my tuner has no issue using these injectors I will keep them, they are good quality after all
    • I already have an Apexi. Just wondering if it is worth putting in something new since the Apexi is likely well over 10 years old, if not 15. I know the injectors work but they already run at less than rated fuel pressure to make them work properly and idle is basically 1% duty cycle or less. Could be better
    • Nice, I would never have thought in that direction. The actual motor is a cylinder....I wonder if there are any cylindrical heat sinks with the right ID  (and if there is clearance to other components). I think adding airflow is still a thing as well....will check it all out next time it is in the air. Wish I had a hoist...
