@John: Needs more dish uleh
yeah if it was a roller i'd probably take it, but an empty pillarless shell is useless :banana:
I thought the same thing. Plus I'd get shot if I brought it home... and not in a good way!
blah blah blah blah blah blah blah responding to everyone but john blah blah blah
fine ;) ignore my post :no:
im scouse not cockney you cock.
I didn't know scouses were such cock donkeys :D
vote now bishes:
http://bit.ly/5BdK9K
Done!
anyone know how much a full HID conversion kit for the r33 gtr would cost, also wana but in bright white parkers, and is it simple to install ? thinking about getting it for my car
Depends what one you buy. They start at about $88 for crappy ebay ones, and go up from there.
oh i c, im lookin to buy something local, would you recommend some kit in particular or should i just look around supercheap auto/autobarn etc and just pick a kit up from there, dont mind paying upto 150 dollars for the kit and bright white bulbs for the parkers.
What is with this bright white parkers thing? You get em too bright and you're going to be rooted in fog.
*edit* and while i've not used them. I imagine the supercheap ones would be comparable to any other in that price range. They're just bulbs and wires really.
Edited by Isola
sorry might have not been clear, i just mean the corner lights, my mate bought a hid kit but he kept the corner lights stock, and it looked weird since he had white bulbs for the headlights while the corner bulb was still yellow, so thats what i mean, here you go have a look at this
http://www.skylinesaustralia.com/forums/R3...;hl=r33+GTR+HID
look at damits post youl know what i mean.
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
