sorry might have not been clear, i just mean the corner lights, my mate bought a hid kit but he kept the corner lights stock, and it looked weird since he had white bulbs for the headlights while the corner bulb was still yellow, so thats what i mean, here you go have a look at this
http://www.skylinesaustralia.com/forums/R3...;hl=r33+GTR+HID
look at damits post youl know what i mean.
well... personally I would have thought that would be common sense to do the parkers at the same time... but you kept saying "Bright white" as though it was the latest bling fashion or something. I thought you were planning on doing something stupid like blue headlights and white parkers.
LOL , alrite well once i get the car back il go and check out supercheap auto then, also planing on geting windows tinted, just checked out some samples and the darkest legal tint isnt dark at all lol
sif tint..
u need to make bishes watch u at red lights touchin ya junk while ur making eye contact with them..
Is that charlieeeee murphy....? Or eddie?
Its funkymonkey
err Charlie murphy
:banana:
Hi! skins!! missed u long time brother!
when are we meeting up for more harassment and phantom hands!
Edited by Redsuns88
Its funkymonkey
err Charlie murphy
:blush:
Name a time and place and im not there
nah... thursday ? I'm on a pinky promise to john :)
pinky promises sound like
make sure u wear your fairy outfit
lol nah ill be there! :blush:
sweet. be good to see ya.
cant wear it, its in the dry cleaners :)
@adam:
You can't put HIDs in the parkers, you want LEDs for them to get the same colour tone (ie white).
Buy full HID kit I assume you mean both high and low beam? This will require two kits, as each kit does 2 bulbs (one per side). You'll struggle to even get two crappy ebay ones for $150.
@adam:
hmmm i c, so how much do reckon it would be for the full set? yes im lookin for both high and low beam, i dont mind paying more but i wana buy local somewhere not from ebay unless its an australian store online like justjap etc,
alrite mate, thanks for the help, im gona get the car tinted first, then i might follow the tutorials and clean the headlights up and buy the HID kits needed , the series 3 headlights would be the easier solution but since they retail around 2 grand a set, cant justify that kind of cash, have been lookin around for second hand ones to pop up for quiet a bit, no luck so far,
but thanks anyway,
I good set will be a few hundred PER KIT.
I'm not sure how much the cheap ones go for locally - I got mine ebay styles :blush:
ebay styles are the way to go if you want hids
    • Did you take the MX5 for a Blat around the Track at all?
    • LOL, "they said it might be slippery"..... 30 seconds in your off, 60 seconds in white twin backs into the corner That new track looks good, and the Datsun was chopping cars quite nicely
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
