Morning! I love it when my boss is in late, and tells me in advance...all i have to do is beat him in by 15 minutes and it looks like ive been here all morning!
Just man up and find her, you sl*t.
I'm lazy. Add to that the fact that I wasn't interested in her last night, and still don't give a flying rats ass today and that's puts you somewhere around 'do it yourself, kent' in the grand scheme of things.
A cunning plan. I like it.
Haha, I get that every day. I'm in before everyone else in this area, so no one knows what time I actually got here.
Morning, sir!
Similar to what I used to do. As long as I had coffee going when the boss arrived that meant I'd been there for ages... seeing as how I'm a coffee addict... It was something I never forgot even if I only beat them by 8 mins or so :)
oh don't give me that!
it's always "john, find this bitch for me. john, cup more firmly. john, where the eff is my afm?"
Since when do I look like the Kunta Kinte up in this motherfucker? I'm not your whipping boy, bitch :)
Edited by Isola
I would try and beat my boss into work but he gets in at 5:45am. So f**k that for a bad joke.
a bad joke would probably be more like telling the one about how a jew, a black man, and colonel sanders walk into a bar... at a temple in harlem.
Haha thats epic winage
You can do it Colin!
it's always "john, find this b1tch for me. john, cup more firmly. john, where the eff is my afm?"
Since when do I look like the Kunta Kinte up in this motherfucker? I'm not your whipping boy, b1tch :)
Yes you are, you just don't realise it yet :(
And wheres the gratitude for lending you the afm in the first place huh?
Since when do I look like the Kunta Kinte up in this motherf**ker? I'm not your whipping boy, bitch :)
BAHAHA *claps*
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
