The price itself is already a BIG step over. Maybe take the evos for something in between. But I heard of evo limitations, maybe in terms of loading or sizes.
just so we are clear...you are talking about SS i am sure, because the RS of old was already a higher spec than the EVO and the highest spec federal had, the RSR is just a slight adjustment of the RS
don't think so bunta
its RS, then Evo, then RS-R is the top model
noooooooooooooooope SS, EVO, RPM then RS which was superseded by RSR
the SS has actually now changed to being called just plain 595
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
