Dodgey carnt you are :D So did I read correctly that the 180 is up and running? When are you coming down for a visit?
im not dodgy, im just saying its an option to get a dodgy but tell the buyer its dodgy :/
as apposed to leading them to believe its legit
and yes 180 is running :D
timing is out and she backfires and gurgles like a champion
going in for a tune/set up timing dyno run either late this week/early next week - once the motor is run in :D
Yeah bin back a week. We had a new Site Engineer start last week on Monday and he quit today. Apparently he has wanted to get out of the industry for awhile and he's looking for a new path to follow. Seriously WTF are you thinking when you go to the interview for the job then. Such a dog act. We are down so many staff it's not funny.
That sux aye. Give John a Job :D
Skylines wrecked skyline resale. And p plate laws.
Who buys a skyline for resale though? Especially a dirty 32 GTS-T :/
I know you love your camber but I need grip damit :D
I don't understand... Camber is better for grip except when going straight, which is when you least need it.
...Unless of course you're drag racing. Which is ghey :D
Stealing my lines....sheesh
Mangs.
You love it
they dont even look at mods, if your horn works and you have no split CV boots and decent tyres you pass
That was what I thought too
im not dodgy, im just saying its an option to get a dodgy but tell the buyer its dodgy :D
You should have seen the state my XF was in when it passed RWC.
My rule: Always assume a RWC is dodgy.
How far out? Don't want to damage that nice new diesel. I has a timing light... somewhere...
One day in the hills - run in done. Watch for speed cameras :(:/
you are such a lazy little fluffy, when i sold the R32 i went to a legit place and it passed easily, they dont even look at mods, if your horn works and you have no split CV boots and decent tyres you pass
And lights! Haha. Yea they're lazy and probably just do the obvious.
and yes 180 is running :/
Sounds good! Dinner date this Thursday night?
This is true . . . And I am planning on getting my lazy ass to tha track one of these dayz
and yes 180 is running ;)
going in for a tune/set up timing dyno run either late this week/early next week - once the motor is run in :)
Noice. What's done to the motor? Did you rebuild it? I thought you just bought a second hand one?
I would but I refuse to recommend anyone for a job. That last guy was recommended to us by one of the Project Engineers and it makes him look like a dick when that guy quits lol.
Who buys a skyline for resale though? Especially a dirty 32 GTS-T :D
This is true.
...Unless of course you're drag racing. Which is ghey :(
Give me one too. I need a job change.
I do too, but this job pays too well
Good stuff :D
LOL yeah. That is true.
rebuilt motor mang 0km :D
well now 283km on it hahaha
how are you running it in sexy?
so far just have been taking the back streets everywehre - trying to vary speed / load - havnt taken her past 3500rpm
going to do an oil change tomorrow and then head up the mountains to finish off the last 250km or so of her run in, then get her on the dyno to sort out all the shittttttt
Do a skid :D
Start giving it some more revs, you don't want to baby it too much or you'll have a soft motor.
I don't mean redline, but maybe 5000rpm (whats an SR Rev to?).
You need to let the rings bed in over a large range of both load and RPM
SR redline is 7500, alright ill start a little more tehehe
ps martin i think im a real contender to challenge your epic dose :ermm: - she doses nicely, especially considering the boost is set on 4psi
Dyno run in FTW, the run in on Annas car took an hour and cost like $70...WIN
Now just have to finish the tune :S
Hills run in FTW. Although with the speeding ticket, it actually cost me more than that :ermm:
Next time maybe I'll go the dyno option :D
ps martin i think im a real contender to challenge your epic dose :P - she doses nicely, especially considering the boost is set on 4psi
I approve <3
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
