hopefully clutch and gearbox back in today, so car be will be heading to dyno soon, hopefully i can pick it up this week :P
*fingers crossed*
it must have been terrible waiting so long to get your car back..... :( fokker ha ha
yeh it has been man, not a good time since im movin to a new unit and all, but it was mainly down to xmas and new years, the gearbox work coudnt start until the guy who has the equipment to do the gearbox came back on the 6th, and then NPC just opened up today, so Dans done everything intime, it was just the waiting for other people to get back from holidays and finish or deliver the parts required, but Dan had given me this timeframe and said things do go wrong so im pretty happy with all that he has done , and thumbs up to ERD, honestly Dan has been a pleasure to work with,
p.s i still wana look at your wingless gtr when im there :(
Everyone is leaving their sarcasm meter unplugged.
unplug battery, put meter back in
hold foot on brake for 10 seconds
plug battery back in
i think you missed it adam, andy has had his 32 out of action for ages due to work being done
correct me if im wrong andy..
Correct!
1 year 3 weeks since last driven
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
