I like to stick my dick in the book and cum all over the pages, then return it to the library. (best i can come up with)
LOL!
John's subtlety is currently a passenger :banana:
Not like either of you were being particularly subtle before that...
I see nothing wrong with my posts. Wonder if there's a name for people that actually have sex with books like there is for people who have sex with other random things. For example, a necrophaeliac has sex with dead things. A dendrophaeliac has sex with trees....
@adam
John is a troll. Don't feed the trolls
ok, so i'm going on holidays as of tomorrow and am going away to tangalooma with 9 other friends. Basically gonna be a fkn booze fest, but I'm wondering if any of you have a favourite/unique drink that goes down awesome at the beach and in the sun. Obviously corona's, pina colada's and mohito's come to mind, but anyone got any other suggestions? I'm taking 2 heinekken keggs, a case of coronas plus a f**kload of spirits. List your drinks ppls
1: get a high ball glass
2: 1 shot vodka, 1 shot White rum, 1 shot gin and 1 shot tequila. ( there may be more alcohol involved)
3: ice, fill with lemon lime bitters and put a dash of coke in
4: ???
5: Profit
called a long island ice tea.
@adam
4: ???
5: Profit
John is pillow pants? Awesome, forgot about the long island ice tea. I've got all the ingredients for it too....some reason there's 5 full bottles of barcadi sitting around my house...guess it's gonna come in handy meow
It's better if you can get proper sours instead of lemon lime bitters. But whatever lol.
How I met your mother is a funny show
Aromatic bitter is what you need, we had a work function where we just drank long island ice tea all night, needless to say i can't remember much after the 5th or 6th one
in for dose challenge, we have a BOV but it doesnt seem to open ever
im in, wen my motors in, dont have a bov :banana:
cefiro cross over :) no bov from factory
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
