Yeah for the 10.5 Ive only got the option of -12 or -22
"-" ??? you serious? I think they only come in 12 and 22 but thats +... Haha. You can be Brandon 3.0
http://www.skylinesaustralia.com/forums/18...37-t293740.html
another one... dont know if its been sold or not and its missing a sticker (no biggy as you can get someone to make them for you for 10bucks.)
'tis true
There seems to be a few lurkers, but yeah too early for most...
0 or less :(
0 is a good number
Yeah for the 10.5 Ive only got the option of +12 or +22
FYP
Give the man a cookie
-ve offset = baller
This is correct.
Will probably be sweet with 10.5 +22 on the rears. no idea on fronts.
http://www.skylinesaustralia.com/forums/Ge...tml&hl=te37
Not the size you're after but yea... perfect size for 265 tyres. Brand new too.
Yeah thats good for a gtr but unfortunately I dont have one :(
Maybe they do. Just check the Rays website and all they have was stars and all those icons for vehicle compatibility. But then again I've never seen any for sale that came in "-".
Nah man your right, I was looking at it wrong
Yeah she's the best bit of that series.....
Haha . . . The first few times I watched it I dint like it that much but then my mate gave me S1 an S2 on my lappy an I started watching them at work when I was bored :(
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
