somebody hit the brakes? thread death mid morning is pretty unusual.
it's not just here, it's the whole QLD section... I dunno what's going on. I've got some BBQ Smiths, and some green solo all set for a posting extravaganza... and... nothing :huh:
Side note : is it illegal to turn your parker's into indicators ?
You'd still need to comply with all the relevant ADRs. So as long as you had indicators visible from all directions (front, rear, sides), and parkers visible from the appropriate directions (Not sure what the rules on parkers are) you should be OK
needs more cowbell...
well there goes my idea
*toss's plan in bin*
Should incorporate the whole water thing into your world domination plans. Just cut off all water to Brisbane and demand 11ty billion dollars and a maxibon and wait for the moneyz to roll in. EZ.
What if they try and take him down during the Maxibon handover? :huh:
SUCCESS!
Always a risk...
in other news: THE INTERNETS IS DOWN!!!!! ZOMG1111!!!!!
Somebody divided by 0, and killed the web gateway at work. Fortunately, I am a l33t h4x0r and have been able to bypass it, but this connection is fookin slow ;)
What if they try and take him down during the Maxibon handover? ;)
Threaten to kick their dogs if they try anything funny :huh:
SUCCESS!
Always a risk...
nice skills.
Fail :huh:
Fail ;)
Win :)
Fail :(
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
