somebody hit the brakes? thread death mid morning is pretty unusual.
it's not just here, it's the whole QLD section... I dunno what's going on. I've got some BBQ Smiths, and some green solo all set for a posting extravaganza... and... nothing :huh:
Side note : is it illegal to turn your parker's into indicators ?
You'd still need to comply with all the relevant ADRs. So as long as you had indicators visible from all directions (front, rear, sides), and parkers visible from the appropriate directions (Not sure what the rules on parkers are) you should be OK
needs more cowbell...
well there goes my idea
*toss's plan in bin*
Should incorporate the whole water thing into your world domination plans. Just cut off all water to Brisbane and demand 11ty billion dollars and a maxibon and wait for the moneyz to roll in. EZ.
What if they try and take him down during the Maxibon handover? :huh:
SUCCESS!
Always a risk...
in other news: THE INTERNETS IS DOWN!!!!! ZOMG1111!!!!!
Somebody divided by 0, and killed the web gateway at work. Fortunately, I am a l33t h4x0r and have been able to bypass it, but this connection is fookin slow ;)
What if they try and take him down during the Maxibon handover? ;)
Threaten to kick their dogs if they try anything funny :huh:
SUCCESS!
Always a risk...
nice skills.
Fail :huh:
Fail ;)
Win :)
Fail :(
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
