Yeah so you guys die in a blaze of glory and I survive and repopulate the earth with rangas? RED POWA!
d00d i just said u would be getting owned by zombie crows!
RED ZOMBIE RANGA POWA!
nah I never agreed with the blaze of glory that Tas mentioned. He can blow himself up if he wants. I'm all about the repopulation :D
im keen for the zombie secks
sif owned by f**king crows. Go far enough away from land and birds aren't a problem anyway.
seen dawn of the dead? they tried your plan and got f**ked up
that was only because they didn't take enough gas and drifted to some random island.
if they had have been smart about it it could have worked.
you really only need to go out a little way and drop anchor. then pick them off one by one with a sniper rifle :D
yer, im with colin on this, i'm crimin' an oil rig to chill in, except i want a speed boat to get from shore to rig, think of the amount of ammo you will waste through in a full day killing, i know in an afternoon/evening of shooting roo's (with a permit) i ran through 20 rounds just taking it easy. You will need to have somewhere safe to relax while reloading all that ammo. Plus oil rigs are awesome town, only a small crew on them so not too difficult to take over.
Rifles eh? hopefully this time next month my paperwork will be lodged so i can get one
Would take a fair bit actually, boats rock something shocking, need stable ground to take them out over even 50 metres
I'm in for the slaughter, but how long you think it will last? I could go for a couple days full on, then back to the rig for party and resupply
Dibs on the Chevy at Tas' workshop in the event of zombie apocalypse
I'll be working out a way to mount a machine gun in the back of the XF quick smart. Whos with me?
I'll help by getting molly knocked up as many times as possible :D
We've already established, house at Petrie is zombie-proof.
I'm disappointed dan :P thought you would have been in for the slaughter
+1
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
