rb26/30 - supercharged
you sure? the fact that the intake is where it is and the first pipe to the cooler looks a lot like a turbo set up to me
yeeeh im sure :thumbsup:
nice bro, just got word from Dan that dyno will be doen tomorrow so by monday i should definately have the car back, mayb even tomorrow if dyno can be finished early, gearbox feels smoooooth after Dan did a test drive hehe :thumbsup:,
u better be out next thursday bro, n since its next week you might even have some time to come over and help with the coilovers :D
Ok well... I"m about to head out once my mate finishes work, probably go past Harrys on the way to baskins... anyone keen? Jase you're northside yeah?
My bad. I'll make sure the next one is cheaper to reply to.
and how is getting things cheaper a bad thing? good to see you got your 5grand worth :thumbsup: lawl.
why don't you quote up your whats your wrong list again, or will it take up another page.?
and to think i work hard and had to help pay for it. and before you think your all cool and start saying shutup man your cars a roller, yes that may be so but even with the motor out its still more reliable then yours will be.
well thanks boys for a sweet night... Wicked cruise. Cant wait to get a good look at those videos my mate took!
As a follow up, I'm hoping to come out tonight for a spin... Harry's and then BNR chapel hill is it? Coming from the northside first, if anyone wants to meet up
Good to see you again :blink:
and how is getting things cheaper a bad thing? good to see you got your 5grand worth :) lawl.
If you were paying attention to the conversation in the first place instead of fapping over ugly ass cars you'd have noticed me say I *did* get my 5 grands worth, and that was the problem, that I should have held out for something better :blink:
awd isn't working... :bunny:
and no air con
and rooted immobiliser that I got ripped off for and it's not even installed properly
and tyres are 20 years old and dangerous as fuck
and rear rims are warped
and afm lasted 4 weeks
and reverse switch rooted
and no air con
There you go, Princess :rofl2: I even quoted it up twice to see if it would "take up another page" but I guess if it didn't take up a page to start with, it can hardly take up *another* page :D
You know the one thing I *didn't* do though. Was blame someone else for it (with the exception of the immobiliser because I think the guy may have been on blow). Some people could learn something from that.
I don't remember you paying my tax return or buying one of my guitars... and that was the only money that I used to pay for it all so far... So not quite sure how you helped me pay for it. Would that have even been possible? Do you even part with money?
and before you think your all cool and start saying "shutup man your cars a roller", yes that may be so but even with the motor out its still more reliable then yours will be.
Got your education for a steal too huh? :(
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
