Hi Tristan!
Thanks for dinner on Saturday :)
Dan still wants your wheels
you want my sr now :)
aand you guys owe me icecream or something
Yeah! I could put it on the ride on mower, which we managed to start on the weekend despite dad's assurance that it 'would not start'.
I already owe you ice cream, you just need to turn up to collect it
P.S. we got sick of waiting for the cab you orded, so waved one down off the street. Took about 10 seconds :)
who is going to ice cream this week
Me me, pick me!
Might car pool it over with Dan...
Speaking of Dan, I think the lucky prick just got to take the GT-R that was traded in for a spin
yeeh thats baller, cabs are shit on saturdays lol
i will if you will
Me me, pick me!
lucky f**ker
Hi Tristan!
Tristan. Thread needs more pics of your car.
you want my sr now ;)
You wouldn't come to ice cream anyway...dog :)
Ride on eh. Dad is buying an SR to keep the paddock in check at home. Should be sick.
I will if anyone wants to come pick me up lolskates.
tehehehe
we could be in, but only if Tristan is because we dont want to be the only tractor
we could do this..
I'm in
If and only if
Geoff's in
+1
i will if you will
ice cream meet needs MOAR nismoh and GTTG
lucky f**ker
Yer *jealous*
Looks like he'd better this week
This ride on is at least a hundred years old. It was ancient when dad bought it, when I was about 5. It had about a 2.5HP engine which I blew a hole in the side of, now its a wicked 10.5HP. But it hasn't been used in ages, needs major service, new blades, and the cutter mechanism and steering both need some work. But will be baller when it's fixed.
If you jump on a train to indro (somewhere near the city if its easier) I'll pick you up. You'll need to train home or get John to give you a lift or something though.
Why not, everyone loves a tractor.
Tristan, you'd definitely better come this week. Free ice cream, and all the sheep will follow :)
am i welcome? i mean with my "secretdick styling", stretched tyred, lowness, sexiness...
ait andy, nismoh and i are coming - ill talk dave into it too
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
