ebay is telling me:
Don't miss out on item 1992 Nissan Skyline R32 Gtst - Manual/Mods/QLD Rego (160393158666)
Maybe I'll add another cent to the current bid?
do it, i wana see how much "fast and furious" put on auto bid
I'll be happy just with the pipe @ $20 :)
I'll bring it and whatever else I find on Thursday. We'll talk business then :)
I don't want to actually buy it but :)
you would need to bid around the buy it now price to win it
But if I win at below the reserve cost, you could still choose to sell it to me and i'd be obligated to buy it
P.S. One more to go!
you cannot buy it under the reserve
update: HKS boost controller is being removed and apexi boost control kit is being put it, apparently when the alarm install was done and the HKS turbo timer was disconnected the boost controller shat itself as well i.e wasnt workin properly because it works hand in hand with the turbo timer or something, hopefully should hit dyno in an hour or so and il be able to pick it up today, *fingers crossed*
If you jump on a train to indro (somewhere near the city if its easier) I'll pick you up. You'll need to train home or get John to give you a lift or something though.
Can't give him a lift if I'm not there :ph34r:
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
