MacGuyver would have built one by now :rant:
True, and I am ALMOST as cool as MacGuyver, however I've been busy :ermm:
Might do that but its a pain in the arse.
Do it you skirt
Qatar sucks.
+1
speaking of serbs where is our little serb?
Who me?
probably off working on his lawnmower :P
Naah, went back to the old place to clean up. F*CKING hot, f*cking hard work, I hate cleaning :(
Sup mangin mangs..... so stuffed from work. Time to get my taco on!
sounds mexican...
mangs
bloody hot
:D
mang
yes it is. F*CK summer
So i drove the 35 GTR today, its a good car
I liked it alot.
So jealous. Wheres my promised pics?
i earn that after tax now...and im bad at negotiating but they would need to literally pay me triple to get me to go and live in a hotass desert!
Same, although i'd probably consider it for double. Do they have any race tracks?
when i was there, they didnt, now they have the Losail International Circuit, mostly for motoGP races, but you can have track days on that, pretty nice track,
also just recently built the Qatar Racing Club has international drag racing championships which Qatar has been winning for the past few years with its Al-Anabi team, you can drag there with street cars as well, and they have a massive skidpad too, other than that they have massive dunes you could go dune bashing on in 4x4s,
however dont expect to buy skylines there, you would be very lucky if you could register one, most popular performance cars there besides the corvettes,shelbys,lambos ferraris etc are the luminaSS ( commodore dont know if you classify it as a performance car), ford mustangs are dirt cheap you can pick up a mint 2003 one for 20 grand, the same would cost you around 50 to 60 grand here plus conversion to rhd, rest is all the same but most cars are cheaper due to no luxury tax.
you know what i dont like?? the only pics i can find are either guys standing in the desert or concept drawings of things that do not exist
I love watchin arab drifts on youtube..... especially the bicyle one/s lollllllll
EDIT:
for hilarity!! Edited by mosquitocoils
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
