no one here streams porn lol? loads quicker haha
nope, we just have sex with real girls instead of our hands*. You should try it sometime :D:bunny:
*except Jason. He meets fat old men on the intertrons instead
Don't call me Marty :devil:
Fine then, i'll call him Tim.
Hey Tim
:D
nope, we just have sex with real girls instead of our hands*. You should try it sometime :bunny::bunny:
Leave jack out of this
He's hot and your jealous :P
Side note :
Job application I just sent
Afternoon Dean,
Thank you for you rejection letter dated the 19th of Jan 2010. It is unfortunate but at this time due to high volumes of corespondance, I am unable to accept this. This rejection letter although is of a high quality and standard and will be kept on file for the next six weeks incase there is a change in my cirumstance.
Looking forward to starting work with you.
Sincerley,
Jason
P.S. You interviewed the guy three times ?
To: skins@secret.com
Subject: Workshop Technician Job
Date: Tue, 19 Jan 2010 12:58:55 +1000
Hello Jason,
Thank you for submitting an application for the 'Workshop Technician' position which I advertised in SEEK.COM.AU. I have been impressed with the volume and quality of applicants who have recognised this opportunity. However; it is my responsibility to screen all candidates and present a shortlist for the owners to consider. The very least I can do for you is keep you up to date with your application. Late yesterday afternoon we interviewed an applicant for the third time and were confident in making an offer of employment. The offer was gratefully accepted and thus the advertised position is no longer available.
Once again I thank you for your application and hope you will allow me the opportunity in the future to place you into employment. If you see a position I am advertising I welcome you to send an application.
Dean
www.cantsay.com
dean@shhh.com
PO box somethimg
Mt Gravatt Plaza
QLD 4122, Australia
This e-mail is for the use of the intended recipient(s) only. If you have received this e-mail in error, please notify the sender immediately and then delete it. If you are not the intended recipient, you must not use, disclose or distribute this e-mail without the author's prior permission. We have taken precautions to minimise the risk of transmitting software viruses, but we advise you to carry out your own virus checks on any attachment to this message. We cannot accept liability for any loss or damage caused by software viruses.
I'll let you know if I get anything back :D
cant do until im married, muslim bro lolz,
porn is all us moslems have before we get married :devil:
porn is all us moslems have before we get married :D
Hahaha, pretty sure the koran says you can't drink alcohol either.... May as well break another rule...lol
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
