i was jst kiddin about the moslem part guys, ive had my fair share of the punani bck in the good old high school days but havent relly found the time once i got to uni, even if i do score im too pissed to remember anythin the next morning, need to sober up, this sem is going to be extremely stressful.
is it just me or can i hear a cricket chirping ?
*face palm*
fag
No u.
Side note :
Job application I just sent
[more stuff here]
I'll let you know if I get anything back :)
That is quality posting right thur.
cant do until im married, muslim bro lolz,
porn is all us moslems have before we get married ;)
Sucks to be you?
Hahaha, pretty sure the koran says you can't drink alcohol either.... May as well break another rule...lol
No wonder they all blow themselves up.
if the hymen doesn't break, you can't count it on the score card :)
Farkin lolskates.
morning mangs
hi colin, hi josh
Sup biznitch.
I took the filter off my phone line last night and got 800KB/s dload but when downloading from anywhere but speedtest it's still slow as f**k. Going to call TPG tonight. Couldn't be f**ked last night.
Sup biznitch.
Are you talking normal downloading or torrents/p2p. torrent speeds can depend on a great many things, so might not be a problem with your line.
f**king score. I got Monday off. Win.
Same. sexy time?
morning mangs
hi colin, hi josh
Morning ;)
Sucks to be you?
lmao
I hate u
Same. sexy time?
Jealous
So whos the best person to talk to in regards to pumping gaurds ? I dont really wana do it but 5000km from a set of bridgestone potenza's isnt really good on the wallet ;) Also once the coolers on ima need the extra rubber on the ground :)
Same. sexy time?
normal dloading is still slow which is probably normal. Haven't tried any torrents/p2p yet. Probably just shit servers that I'm dloading from rather than my line. Gay.
http://www.guardrolling.com.au/ that is the guy that I used to roll my guards. Not sure if he's any good with properly pumping guards. I would probably go see a panel beater if it needs to come out a fair bit.
So whos the best person to talk to in regards to pumping gaurds ? I dont really wana do it but 5000km from a set of bridgestone potenza's isnt really good on the wallet :) Also once the coolers on ima need the extra rubber on the ground ;)
I has a hammer and pliers :)
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
