how about we take this battle to the hills?
hhaha
yes problem sovled martin! only a couple more smaller issues to work on then get that turbo on. I might have an idea for the pulley for the water pump
sif mount that shit.. just place it infront of u lol and bucket to catch th shit
rofl im still slightly rocking from the boat.. lol.. im like taking a piss.. thinking wow.. since when does this toilet have a swell?
Edited by Redsuns88
@john: Had to repair that power cable after looking at it mang, all 3 wires were showing copper :P . All good now :D . Seems cold.
Air con fitting day tomorrow :rant:
Win :P
Manging mangs
Work is of the ghey today. Think i might pretend to be dead and get the day off
I think you could pull it off.
mmmm, day off.
awesome.
Hai five!
Think I shall detail the car today.
Manging mangs
Would kinda suck if u did that..
pretend to be dead then the next day u come in everyone are like
"skins skins!!! what happen buddy thought u was dead!??!!"
"Meh i dunno.. just started breathing again!?!"
I'd just put it down to that 24hr death bug that's going around.
I had that on the weekend, although mine was somewhat split into 2 x 12 hour deaths, on both saturday and sunday daytime. By night time, it was a miracle! I was alive again!
On a side note, I hear it's related to periods of heavy drinking, and can flare up immediately following a cab ride home at 5am.
Its highly contagious. There is only one cure and thats more of what you had the night before.
Hey Geoff
:cool:
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
    • Who tuned it? Have you spoken to them about the hot start issue yet?
    • injectors were upgraded (1000cc), stock turbo high flowed, return flow infercooler and ecu nistuned before tuned
    • Injectors? Note, there is no way that I would run E85 on stock injectors. They are too small.
