AAAAhhhhhhhhhhh you caught me lurking
Didn't have anything good to say...... way too drunk hahahahaha
lol?
nazi mod that deletes all the good posts... but none of the good stuff gets deleted on here haha
Yeah what he said.
Oz day has one hour left to run and I choose to spend it at work ? How unaustrayen is that ?
Totally unaustrayen ey bloke.
I got pulled over yesterday for my car being un-australian :). Farken lol, so we took the XF out for lunch, its totally austrayen.
Work day again today :) get whoring, slarts
http://www.skylinesaustralia.com/forums/Te...33-t304550.html
hows this?? I'm thinking of getting them since the price is right and if its not thats stiff.
Good price but Bilsteins > Tein. That is all.
Yeah what he said.
I got pulled over yesterday for my car being un-australian :) . Farken lol, so we took the XF out for lunch, its totally austrayen.
I didn't have a single alcoholic beverage yesterday. I felt so bad for being so una'strayen so I donned my strayen flag like a cape and went into Surfers and beat up some indians. Im so f**kin strayen.
F*CKING LOL! I'd pay to see that
No alcohol ? Soft... But beating up on injuns.
Very farken strayen.
Is beer for breakfast classed as a meal ? :)
tree fiddy for a ticket :)
Breakfast of champions mang
f**k yeah do it :(
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
