you'll live :P
Will i ?
and why aren't you on MSN?
I imagine you're at work. Fix my water.
No laptop at the moment.
Stupid work.
What's wrong with your water ? Not enough wet ?
Stupid work.
for the past week my cold water has been coming out warm... even at 3am. make it go back to cold!
well then... if you're just going to give me the silent treatment... I'm going to go to bed.
Some of us have to work you know... Still working on that cold water issue :P
oh so you can take time to watch tv, but not talk to me who was missing for a week and presumed ded or employed :P
nope just ded
im talking to you now... sheesh
so how ded were you ? a little or a lot ?
    • I did basically the same procedure on a ZF6HP but the reason to pull the valve body is to replace the seals between the valve body and the transmission which are notorious for leaking pressure with age causing poor shifting and burning out the clutches. If you just wanted to exchange all the fluid you should be able to undo one of the transmission cooler return lines to drain into a bucket while using the pressure filler to keep it topped off.
    • The title should have posted "EFR7670 exhaust housing selection RB26" I can seem to edit thr title on my Android.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
