I already finished off my - Chicken, corn, carrot, potato, pea, mushroom and onion soup before. When Dan was still with us.
Side note: Searching "Super Asian" on Google with safe search off is just awesome :P greatoo image find!
There's a safe what now ? :down:
How you do that ? :)
ugh... need to lie down again.... body not happy with egg :P
you malergic to egg
you eats the egg in the sandwich
where did you go wrong again ?
not surprising. most rice dishes are crap.
it is so going to make me fart. its all organic and got spinach,pumpkin and leak.... mmmm recipe for disaster.... if only jack was here so i could give her a dutch oven
I know. I always do it. Egg is just too tasty to not eat. Same thing happens with milk :(
I don't know about you but I try and steer clear of stuff i'm allergic to.
Maybe i'm malergic to this resoto
:P:down::)
pumpkin & spinach FTW
leek & rice FTL
leek & rice FTL
is that kinda like bowl of past + bowl of anti pasta = empty bowl ?
but eggs and milk are so tasty!!
so is crab but that makes me of the dead :P
so no eating for me
Are you serious ?
Abc selling music cd's for people going to the gym.
Cardio classics volume 2 all full of classical music that is supposed to get you up and going at the gym.
:P
Are you serious ?
:P
Am I serious? Or is ABC serious?
If me - yes. If ABC - also yes!
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
