Yeah but R31 owners are too tigh to pay for them..
there is one on here for 2700. Bit rich.
R31 house dont list there repo ones anymore :P
I meant the club 'people-who-want-a-GTSR-manild' not the r31lowballclub. Only douchebags join that club :P
But yeah, sif 2700 for a manifold
Edited by Smity42
Jason wont fix anyone's water. Mine is still warm :P
That's it im turning your shit off
:P
what an a*shole
MF/
join the club
Mile high club ? So in
Hell keen. one of these days I need to man up and ask one of the virgin blue hosties
What did your friend request say? :P
"you have fantastic funbags, and I really want to motorboat them"
Naah, I never write anything, I just leave it blank. 99% of the time they accept it anyway, especially if you've got a 'mutual friend' or 2 up your sleeve :P
pussy, shoulda gone the motorboat option :P
:S Well atleast you have the good crank now :P
couldnt agree more! im actually kinda happy about it as the whole idea of the crank collar didnt please me that much
Morning bitches
Had an interesting day yesterday, my crank was fokked, so i had to go buy a new R33 GTR one, no crank collar for me!
I would have thought that would definitely be cause to put an SR in
Nah, you can have 'em.
You're a good friend :P
That's what she said
Everybody wants that crank.
tis crank porn tbh.
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
