Grrrrrrr can't get damn cat out..... it's held in well with studs + bolts. Got the bolts off but the studs it seems are welded to / are a part of the cat.
Any tips?
Do I have to remove the whole back section of the exhaust to get the cat out? I think I just realised this to be true :P
just work with the wiggle room
exhaust is on hangers, should be able to move it back a bit to get the cat out
its a c*nt of a job on my car, thats why i decided i wasnt going to swap the decat pipe in every track day after doing it once
LOL, found dad's old paperwork for the ride on:
He bought it second hand in 1994, and it was old then:
'twas an 8HP apparently (I thought it was less) but that engine blew up.
He bought the new 10.5HP engine in 1998, at the time it was the biggest one we could get that fit:
I'm not sure how old the mower itself is exactly but I did find the instruction book:
If you look down the bottom, you can note the SIX DIGIT phone number.
Now I remember going from 7 to 8 digits some time in primary school, but 6?
Some quick research, and this very informative page tells me that "Brisbane went to 7 digits in 1975". Therefore, we can conclude that the beast is older than 1975. Thats 35+ years!
And note: it is a mini tractor, not a ride on :P. EEESSSSSSS AAAAAAAAAAAAAARRRRRRRRRRRRRRRRRRRRRRRRR!!!!!!!!!!!!!!!!!!!!!!
Look, you can (could) even get tractor attachments for it:
Definitely needs turbo love
Don't talk to me about ride on trailers, made that mistake once, hung over after new years, we decided to ride in the trailer to clean up the mess we made couldn't find the holding pin to keep it on, going down the hill very fast and the trailer popped off, catapult anyone?
bugger
we could MAKE a trailer for it
matter of fact, there is a small box trailer in the back yard I doubt has any chance of ever getting road registered. Could convert it to a tractor trailer
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
