If you ever did that to a caterham, i would kill you.
We used to have a genuine Lotus 7, dads been on the search for a caterham though
Genuine lotus 7 i wouldnt but I don't see the harm in putting one in a caterham. No different than putting an SR, 4AGE or F20c in it.
Would go well in a caterham or a radical or something small and light like that. Would still haul arse in an s13 aswell lmao.
yep 400hp in a s13 goes quite nicely! Though i just read the reccomend a rebuild every 30 hours? screw that
Lost that SR Love? :D
Never! but V8s with ITBs are sex, and when was the last time you saw a v8 s13?! It would be an interesting project. Perhaps you need one for your mower?
afternoon ;)
:happy:
afternoon :D
hey mang, coming out tonight?
Hahahahaha, I like your thinking. Might be a plan if the turbo option doesnt work out :happy:
Ive still got the SR turbo here if you think the mower could push it!
FYI caterham is made under license from Lotus.
Technicaly speaking a caterham is a Lotus...
Technicaly speaking you are a guy but every one knows thats not really the case! :happy:
I'm willing to give it a go :D. If you're going to come out tonight, bring it along plz ;)
Will do
But a real lotus 7 hasn't been produced since what, the 60s? Early 70s maybe? It would be a genuince classic
caterhams are a dime a dozen (figuratively speaking :happy:), and they put any of about 100 engines in them from factory anyway.
Kinda like 32s. They are everywhere, everyone hates them, not worth a penny. But 31s: they are classics. Something special. Everyone loves them. Worth a fortune. Etc. :D
<3
<3
Caterhams aren’t, PRB’s and Westfield replicals are everywhere.
A current Caterham is still a $100k car..
a 70's - 80's Caterham will bring anything from $30k - $70k
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
