Caterhams aren’t, PRB’s and Westfield replicals are everywhere.
A current Caterham is still a $100k car..
a 70's - 80's Caterham will bring anything from $30k - $70k
base model goes for about 13,000 pounds in the UK (kit form). Granted thats probably still about $50k AUD :happy:
yep 400hp in a s13 goes quite nicely! Though i just read the reccomend a rebuild every 30 hours? screw that
Never! but V8s with ITBs are sex, and when was the last time you saw a v8 s13?! It would be an interesting project. Perhaps you need one for your mower?
:happy:
LS1 S13 do it.
Don't think the will sell you a Caterham kit unless you're in the UK. You can only import the pre assembled ones from their factory. Not 100% but I'm sure I've read it somewhere on their site.
Turn key, ADR spec, will cost you about 100k on road for a "2010" one.
Correct.
Transport are comming down HARD on the imported 70's and 80's Caterham's at moment as webers are not ADR spec and they didn't come with collapsible steering columns, amoung other things
Caterham have beaten us to the punch. Supercharged 2.4L V8. 115k pounds though.
http://www.autoblog.com/2008/02/26/caterha...on-mark-scares/
holy sh*t!
LS1s are dirty heaps of shit
+11ty
Would be the way I'd go for a v8 S13. It has all been done before and there are a few places doing kits now. Easy 400hp and dickloads of torque forever and ever amen. No heavier than an RB26 either.
You come (almost) every week, doesn't need moar you.
I was listing the slackers who haven't been turning up lately
True... last week was the only week I haven't been there so far. Although I did turn up... just it was when you and Dan were leaving :D
in my experience they are surprisingly un-torquey for the size of the f**king things!
They make like 350hp at 4kish and 350ft lbs of torque from 2k. Easy enough for an S13. exhaust, intake and a reflash should see 400hp and more torque again
It's still 5.7L's of pushrod shit.... If you'd want a v config motor that's kinda unique go the vq30det. 210kw's and 386 Nm @3600 rpm from factory :)
Whos coming out tonight? Needs more tractors, emos, croats, SAUQLD members, boats, gabnrs, etc
No tractors, no emos, no SAUQLD peeps, no boats and no gabnrs :(
Just a croat and some etcs. f*cking weak effort guys :)
It's still 5.7L's of pushrod sh!t....
+11ty
Morning boys and girls :D
Morning mang
Can someone please look at this picture and tell me what the highlighted areas represent?
Im guessing here, but i reckon the 88/88/80 is the amount of dish, and the 51/39/31 probably has something to do with how much brake clearance you get...
EDIT: Or possibly the other way round...
Edited by Smity42
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
