Caterhams aren’t, PRB’s and Westfield replicals are everywhere.
A current Caterham is still a $100k car..
a 70's - 80's Caterham will bring anything from $30k - $70k
base model goes for about 13,000 pounds in the UK (kit form). Granted thats probably still about $50k AUD :happy:
yep 400hp in a s13 goes quite nicely! Though i just read the reccomend a rebuild every 30 hours? screw that
Never! but V8s with ITBs are sex, and when was the last time you saw a v8 s13?! It would be an interesting project. Perhaps you need one for your mower?
:happy:
LS1 S13 do it.
Don't think the will sell you a Caterham kit unless you're in the UK. You can only import the pre assembled ones from their factory. Not 100% but I'm sure I've read it somewhere on their site.
Turn key, ADR spec, will cost you about 100k on road for a "2010" one.
Correct.
Transport are comming down HARD on the imported 70's and 80's Caterham's at moment as webers are not ADR spec and they didn't come with collapsible steering columns, amoung other things
Caterham have beaten us to the punch. Supercharged 2.4L V8. 115k pounds though.
http://www.autoblog.com/2008/02/26/caterha...on-mark-scares/
holy sh*t!
LS1s are dirty heaps of shit
+11ty
Would be the way I'd go for a v8 S13. It has all been done before and there are a few places doing kits now. Easy 400hp and dickloads of torque forever and ever amen. No heavier than an RB26 either.
You come (almost) every week, doesn't need moar you.
I was listing the slackers who haven't been turning up lately
True... last week was the only week I haven't been there so far. Although I did turn up... just it was when you and Dan were leaving :D
in my experience they are surprisingly un-torquey for the size of the f**king things!
They make like 350hp at 4kish and 350ft lbs of torque from 2k. Easy enough for an S13. exhaust, intake and a reflash should see 400hp and more torque again
It's still 5.7L's of pushrod shit.... If you'd want a v config motor that's kinda unique go the vq30det. 210kw's and 386 Nm @3600 rpm from factory :)
Whos coming out tonight? Needs more tractors, emos, croats, SAUQLD members, boats, gabnrs, etc
No tractors, no emos, no SAUQLD peeps, no boats and no gabnrs :(
Just a croat and some etcs. f*cking weak effort guys :)
It's still 5.7L's of pushrod sh!t....
+11ty
Morning boys and girls :D
Morning mang
Can someone please look at this picture and tell me what the highlighted areas represent?
Im guessing here, but i reckon the 88/88/80 is the amount of dish, and the 51/39/31 probably has something to do with how much brake clearance you get...
EDIT: Or possibly the other way round...
Edited by Smity42
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
