Its the 2nd thursday. Harrys with John, Adam and a few others. A 34gtr rocked up today. Rich bastard with a mate that drives c63 amg.
Those car's were fkn hot..... Jizzlemynizzledizzle
On topic
Not sure how that is on topic, but f*cking lol!
massive bailout?
Naah, they turned up eventually. Luckily tas caught me with about 2 spoonfulls of ice cream left, once that was gone I was outta there...
It wasn't a black one by chance? With what seemed to be carbon fibre everything, and black (maybe nismo) 5/6 spoke wheels?
