f**k yeh man! thats soo rad :P
ill donate an sau sticker or two if you want :ermm:
Yeah I was meant to get some off u ages ago :)
Can u post em to my house? PM me your bank details an Ill put some money in your acc ?
dan your address is simply class and baller-ness
its like;
"i live in MIAMI BEACH MO-f**kERS!"
"yeeeee thats right, in a MO-f**kIN' AVENUE YA HEAR?!"
"ah yeh ah, word,word, REMIX"
"album out june 23rd, PEACE"
and then little john is like
"YEEEEEEEEEEEEEEEEEEEEEAAAAAAAAAAAAAAAAHHHHHHHHHHHHHHHHHHHHHHHHHHHH"
its like;
f**kINLOLINESS :ermm:
Your a mad kant :P
I think that may just be signature worthy :)
HAHAHAHAH freakin loving the sig dan
This just in: I've decided to take up guitar again, get in a band and become a rock star
Yeah its wicked aye . . . All thanx to Astro's mad rapping skillz !
Can I join your band ? I cant play instruments or sing but I wana be a rock star and <3 all the groupies :)
7.8L 2 stroke...
naah needs an L series with tripple webbers
mmm webbers
Before you do. Consider this advice from Reel Big Fish.
Hey you ppl of vast knowledge an stuff :( . . . . I wana get an oil cooler but dont know what size will suffice :)
As you know my cars a streeter but I have plans of visiting the sprint track in the near future!
Can someone please help me out ?
13 row or 16row
unless u want to roof mount a 19row
one of the easiest ones to come by are the G-rex oil coolers im sure there are a heap more but for me thats the quickest ones
HKS also does their own brand.. PWR are nice since ur on the coast.. can drop down to ormo or whatever that place is called
make sure it has a inbuilt thermostat.... be nice to get a oil filter relocator as well.. makes hassle free..
Edited by Redsuns88
13 row or 16row
Cooool
Ive got a G-rex oil filter relocation kit already so I guess Ill just stick with that brand ? You know how much a 13row G-rex is ?
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
