E30 M3 is too old for work, I cant afford an E46 M3 out right and I refuse to get a loan and I don't think i'd be 100% happy with an E36 M3 (3.2 6spd spec).
I want an SUV, Range Rovers are too much for me to buy out right
Seems pretty logical. Apart from the wanting an SUV but too each his own. Defects manager chick is looking for an X5 atm or the merc equivalent.
X6??
Whats that? If I'm in Brisbane I'm in!
X6 WTF is the point of an X6 btw? They are completely f**king useless...
explain?
E30 M3 and then using it for work would be :)
I'll come along to watch you all make fools of yourselves in the zorb..... and maybe rip some skids in the big field you go rolling down :)
I won't be Zorbing it up either. Let's do skids together!
explain?
E30 M3 is too old and too rare to be using on a daily base - everything about them is a bit of coin to replace and high kay, daily driven ones are never worth the same
Got any idea's - must be euro only
oh ok then. Thought you meant it was some work restriction.
You just made a friend
No zorbing? lamers...
You just lost one
just about to take my dad to the bowls club...
http://www.asio.gov.au/surveillance/meet-our-people.htm
im going to apply :)
That.looks.f**king.sick.nuts. I am f**king going to apply!! Once I find out more...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
