Lend me your eyes, oh posse!
I left work this afternoon, turned a corner (albeit somewhat sideways?) and went up the hill, never more than 65kmph... speed camera truck on opposite side of the road, on the side where traffic would be going downhill.
It flashed as I was coming up to it :D
Do you think its possible the guy inside set it off manually to get my plates etc?
OR is it more likely someone going the other way was speeding at the same time? Which side of the road/which way do they face?
EDIT: Yes, dumb, I know... shouldn't be doing stupid things.
Edited by mosquitocoils
They for the side of the road they're on - you should be fine.
OR - they take photos of the traffic going the same direction that their camera is pointing (usually the same side of the road they're on - but I've heard of some vans that have 2 cameras)
But I still think you'll be fine.
why did u want me to go home?
well... my car is driving like a charade, really need to put that goo on my coil pack. I was supposed to go to Jason's place to do it... but he's disappeared off the face of the earth... and I don't have sockets :D
Hmmmmm thanks for that... yeah I just hate the feeling in the pit of my stomach right now :D So dumb hahahaha ah well
well... my car is driving like a charade, really need to put that goo on my coil pack. I was supposed to go to Jason's place to do it... but he's disappeared off the face of the earth... and I don't have sockets :O
What do you need sockets for? Removing crossover pipe + coilpack cover etc? Or are you without coilpack cover? If you're without then you just need a phillips head screw driver... although you've probably thought of that already hahaha
unlucky. I can probably give u a lift if you need - call/sms me if you do as I'm about to p*ss off
It's driveable (just) so don't need a lift, thanks though!
removing strut brace, crossover pipe and blow off valve.
got allan keys and screwdrivers. Thought about trying it with my shifters, but it'd probably take me all fkn day
True where do you live? You can swing by mine and do it in my driveway if you want tonight?
That does not sound good
so, i finished work not too long ago, now im chillin here, just assembled my new snap-on air compressor, its a little oversized to say the lest.
I need a 15amp power point wired into my garage now......
It flashed as I was coming up to it :blush:
they can get you on both sides of the road. old boss got done by one with me in the car. camera was on the other side, flashed as he went past doing 70. got the fine two weeks later.
good luck. hopefully it was for someone on the other side.
That compressor looks bad ass :blush:
Don't the cameras have to point the same direction that the car is travelling though?
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
